battery disconnect
Old Sep 24, 2004 | 01:02 PM
shabbey's Avatar
Default battery disconnect
I will be disconnecting my battery on my 1.8t and need to know where I can find the radio code needed to get it going again!! any suggestions?? Sharon
Old Sep 24, 2004 | 01:07 PM
dudley doright's Avatar
Default RE: battery disconnect
Check your manual, it should be there. Otherwise, you may have to go to the dealer.
Old Sep 24, 2004 | 01:25 PM
shabbey's Avatar
thanks dudley, one last question. is this code for the radio only or is it to get the car started again?? just a bit confused.. sharon
Old Sep 24, 2004 | 01:57 PM
I think it is just for the radio. However, other may chime in on this one and give you a better answer.
Old Sep 24, 2004 | 02:10 PM
shabbey's Avatar
thanks again.. I called a couple of dealers and they all said it was for the radio only and that i can find this information with my owners manual. a seperate radio manual.. again. thanks for everything. I blew my timing belt.. and am taking the head out... have a good one.
Old Sep 24, 2004 | 04:31 PM
Jestnomen's Avatar
6th Gear
It is definitely just for the radio. If you can't find the code in your manual, its also in the trunk's spare wheel area or on the trunk lid. It should be a little sticker. If you find yourself disconnecting your battery often, you might want to invest in one of these. I find mine very handy.
Old Sep 25, 2004 | 04:08 AM
SlimChriz's Avatar
Dont forget to do a TBA after you reconnect the battery
Old Sep 25, 2004 | 11:41 AM
Jestnomen's Avatar
6th Gear
just in case tba= throttle body alignment
Old Sep 27, 2004 | 12:38 AM
Doose's Avatar
Can you do that without a VAG-COM?
Old Sep 27, 2004 | 02:55 AM
SlimChriz's Avatar
yes
