the best air filter...
Old Oct 25, 2007 | 05:11 PM
jonsaudi's Avatar
Default the best air filter...
Hello,
I'm looking to replace my dirty air intake filter. Should I go OEM or aftermakt (K&N, Bosch, Fram, etc). I've heard of stories about replacing air filter with aftermarket and how it triggers the CEL on or other instances that affects the performance. Then again there are other aftermkts that performs well than OE, but whoch ones? Any opinion? What's your experience?
Old Oct 25, 2007 | 06:02 PM
18tq_redflag's Avatar
Default RE: the best air filter...
What ever you decided to go with, it's a PITA to put in because of the thicker seals.
Old Oct 25, 2007 | 06:04 PM
Flip's Avatar
K&N is probably the best out of those you named.
Old Oct 25, 2007 | 06:07 PM
Flip's Avatar
I have an Evoms intake and an aftermarket cone filter and unless you put the MAF sensor in backwards you shouldn't get a CEL.
Old Oct 25, 2007 | 06:29 PM
CRAZYHAWK's Avatar
MAHLE LX622
www.rockauto.com
sells it for $7.67.
Old Oct 25, 2007 | 06:35 PM
jonsaudi's Avatar
I found a few posts from here and everyone has mixed opinions on which air filter to go with. From what I gather, oiled air filter can possibly damage the MAF, and that there's not much improvement than an OE paper filter. Also, with oiled air filter, such as K&N, will require more maintenance(cleaning, oiling up properly) as oppose to dipose old and replace with new. I'm not sure anymore, but it looks like I'm leaning towards OE since I'm not looking to mod my car as of yet. Is really a PITA to replace these? Should I consider having a tech do it?
Old Oct 25, 2007 | 07:16 PM
crayzdavy's Avatar
Go K&N for your OE airbox.
As far as I know, oil in the filter only effects MAF witha CAI mod (cold air intake-(cone K&N). This why I didnd't put mine on.
Although it seems that MANY people are running CAI's in theie car and have no problem.
Old Oct 25, 2007 | 07:27 PM
Audi_Skydiver's Avatar
If you get a K&N just make sure to wipe off the excess oil for it and you will be fine. Thats what i did and I don't have any problems. That reminds me, I should clean it out.
Josh
Old Oct 25, 2007 | 08:39 PM
aikibil's Avatar
put k&n in my last four cars. great product. clean and reoil once a year. never have to buy a replacement, just the oil and cleaner. im still on my first bottles from 5yr ago. not so much the audi, but in my spyder it made a huge difference. dont know bout the maf probs as mine was bad when i bought the car (another item ive replaced. need to make a list of these). ill reoil my filter in jan, but i expect that'll be to late to help ya.
a4cab's Avatar
I put in a K&N 5k ago. No problems, other than had towrestle with getting the original filter out and puttingthe K&Nin. What a mess. They must charge a higher than normal rate to change the air filter. Stupid design. The engineer who designed the assembly should be never be allowed to get close to a
CAD system again.
My K&N was new out of the box so wasn't a problem with excess oil. You could have a problem if you
clean and go nuts with the oil before replacing. When it's time, I'll be careful with oiling.
A4 Jed
Jun 23, 2013 06:13 PM
elburko91
Mar 22, 2011 07:27 PM
Niclipse
Feb 9, 2009 01:39 AM
ironman
Apr 16, 2007 03:53 PM
