Best source for parts? Suggestions?
Old Aug 22, 2004 | 03:46 PM
david9999's Avatar
Default Best source for parts? Suggestions?
My 2000 A4 1.8tQ tiptronic now has 81K miles. Although the manual from the dealer says that the timing belt should be changed at 120K miles, after reading the newsgroup about early failures, I'm starting to lose some sleep.
Time for a timing belt, tensioner, roller, water pump, thermostat,
Drop the oil pan and replace transmission filter, put in new oil in differentials.
Although there is a myriad of potential sources out there, whom do you suggest (other than the dealer)?
BTW, what is the suggestion for transmission fluid? Pentosin?
Thanks
Old Aug 22, 2004 | 04:03 PM
Jestnomen's Avatar
6th Gear
Default RE: Best source for parts? Suggestions?
ECSTuning.com sells all the timing belt parts you will need. They even have a kit called the "ultimate timing belt kit".
When I changed my tranny oil, I just bought a jug of it from the dealer.
Old Aug 23, 2004 | 03:48 AM
s4ddriverr's Avatar
I like Mobil trans fluid but thats just because i use their engine oil. For you differential fluid I would recomend Redline Fluid it makes everything even smother.
bgt12
May 16, 2014 11:21 PM
billo
Oct 29, 2007 10:24 PM
Snowhunter
May 24, 2005 11:29 AM
david9999
Aug 23, 2004 10:03 PM
sammydafish
Sep 15, 2003 01:45 PM
