BIG TUrbo Question
Old Jan 29, 2007 | 07:17 PM
SRT4OWnerwj's Avatar
Default BIG TUrbo Question
Planning on getting a big turbo, i want somewhere along the lines of a 16g turbo. Thinking about porting the exhaust mainfold and intake manifold. What size external wastegate should i get with the turbo. Im thinking something along the lines of a 38 mm wga.Im thinking about pumping 20 lbs of boost. I'm getting 650 cc injectors or maybe i should just get a fuel pump with a return line? Anyways let me knw what you guys think
Old Jan 29, 2007 | 07:21 PM
Jeff's Avatar
Zombie Defense Force
Default RE: BIG TUrbo Question
get a t3t4. 38mm tial wg. 550cc injectors. get an atp manifold and port it. dont need to touch the intake manifold. no need for a fuel pump or a return line
Old Jan 29, 2007 | 07:54 PM
Amze's Avatar
I don't beleive a word the kid says.
Old Jan 29, 2007 | 08:03 PM
Boostfed13's Avatar
I think this is the best kit for the money.
http://www.atpturbo.com/Merchant2/me...ory_Code=VVWTK
ATP sells a fueling kit with injectors and ecu tuning to match the kit as well.
The Tapp Auto world fastest A4 is running an ATP turbo set up 380 wheel HP with just bolt ons. They now have the car running 10.82 @ 130mph and 570 HP.
Old Jan 29, 2007 | 08:23 PM
Jeff's Avatar
man i wish i would have dyno'ed my car at 40 psi
Old Jan 29, 2007 | 08:28 PM
Amze's Avatar
Jesus christ thats insane....
Old Jan 29, 2007 | 09:26 PM
Slowb5's Avatar
the man is quite nuts.....
Old Jan 29, 2007 | 09:43 PM
sean1.8t's Avatar
ORIGINAL: Boostfed13
acually Chris Tapp was running a run of the mill GT35r on a 2.0L engine with his own custom tune.. none of it had to do with ATP.. and yes that car DID run 10s but since then the car was sold to a dealer for like 4 grand and a new owner blew it up putting pump gas in it iirc
ORIGINAL: SRT4OWnerwj
what whp and ET goals are you looking for.. it's going to be easier to not use a mitsubishi turbo and go with a Garrett.. but tell me your goals and i can tell you what would be better suited for your car
Old Jan 29, 2007 | 11:02 PM
Lazer Viking's Avatar
info about your car would help
you also need programming
exhaust
fmic
etc..etc..
Old Jan 30, 2007 | 12:46 AM
SMoLiK's Avatar
www.srt4forums.com
www.neons.org/forums
SMo'
EvoTillIDie1
Mar 5, 2014 10:42 PM
98A498
Oct 12, 2006 08:06 PM
keko2004
Aug 30, 2006 02:44 AM
zat0rsk1
Aug 17, 2006 11:36 PM
west2005
Aug 13, 2005 06:46 PM
