Bigger Capacity oil filter question
Old Sep 20, 2006 | 11:23 PM
SalemstanA4's Avatar
Default Bigger Capacity oil filter question
Hey, I checked out the oil and filter posts and went on-line and ordered a package of 5 Mann oil filters the larger ones.
I looked at another site and they had a disclaimer that the larger capacity were only to be used on specific cars. It mentioned a TSB. Looked for the TSB and couldn't find it.
Does anyone know the TSB info, or if the larger capacity filters will work on a 2001, 1.8 engine?
Thanks
Old Sep 20, 2006 | 11:37 PM
onepoint8tee's Avatar
Default RE: Bigger Capacity oil filter question
Sludging is most common with the B5 so 96-01's should have the larger filter for sure. I have heard of a few B6 sludge problems so Im sure it wouldnt hurt to use it on a B6 too, if it fits7
Old Sep 20, 2006 | 11:41 PM
BadLuckAudi's Avatar
if you run synthetic you should have any sluge problems at all
Old Sep 20, 2006 | 11:49 PM
Here is the TSB w/part # that refers to the larger filter:
Using synthetic oil is the main thing that will reduce sludging, and the larger filter allows for better circulation which also helps to reduce sludge from forming.
[IMG]local://upfiles/10408/D1BA354F0EAF4776A83ED7546D650EE5.jpg[/IMG]
Old Sep 21, 2006 | 01:20 PM
Thanks for the info!
Old Sep 25, 2006 | 04:42 AM
dankhound's Avatar
The bigger filter was used on all 1.8 a4's. The tt still uses the smaller filter. See my other post on the sludging issue.https://www.audiforums.com/m_352035/tm.htm
OOA
Nov 17, 2012 01:33 PM
gone postal
Oct 10, 2009 11:02 AM
flynnr
Apr 8, 2009 10:48 PM
Niclipse
Feb 9, 2009 01:39 AM
a42point8awd
Sep 14, 2007 11:30 PM
