black rings???
Old May 18, 2005 | 11:03 PM
BFlan2001's Avatar
Default black rings???
i'm gonna give the clear coat a couple more hours to cure and then i'll start cutting out the 3m tape...what do you guys think i should use to clean the trunk before i put this badge back on?
[IMG]local://upfiles/6332/01F6CD3497344C6EB9166BCBD87C2B33.jpg[/IMG]
Old May 18, 2005 | 11:06 PM
Skibos's Avatar
Default RE: black rings???
can u take a pic i wanna see what it looks like i was thinking bout doing that..... take a pic before u put it on plz
Skibos's Avatar
o lol
now it is up
Old May 18, 2005 | 11:12 PM
BFlan2001's Avatar
mine didn't turn out as well as i wanted, but every time i try to paint, rain clouds rush in...it never fails, no matter how sunny it is.....but i did it anyway in the super high humidity....it took quite a while, i sanded the chrome with 150 grit, cleaned it w/alcohol, sprayed two coats of primer, cured it with a heat gun (cause i'm impatient like that), wet-sanded with 600 grit (important step, do it right, get in all the cracks), sprayed a few base coats of gloss black...then i sprayed on a thick clear coat and cured it with the heatgun again...i did basically the same thing with my front grill trim and front rings...
EDIT: .....getting anxious again....they're going in the oven....
Old May 19, 2005 | 12:49 AM
BFlan2001's Avatar
here's the finished product...not installed yet..i have to wait til the rain stops so i can clean my car first...
[IMG]local://upfiles/6332/F124B079DA094CDAA81E60852BD26319.jpg[/IMG]
Old May 19, 2005 | 12:54 AM
PandaXpress's Avatar
nice maybe i should black out mine
Old May 19, 2005 | 01:13 AM
Covz's Avatar
Hey im doing the same thing! My front one is done and im on the back one now also.. should i use 3m double stick tape or wat? would that tape leave too much of a gap?... that red stuff you have on there looks like puddy.. is that the tape??
Old May 19, 2005 | 01:36 AM
BFlan2001's Avatar
covs, this is the tape i used..the widest i could find was 1 inch, and it worked perfectly, any bigger would have meant alot more cutting...
there are a few different kinds of 3m double-sided tape, this is the strongest that homedepot had, and it's also the thinnest. i'm going to heat it up pretty good with the heat gun before i stick it on, so there shouldn't be any gap at all. i don't think it's any thicker than the factory adhesive...
i just rolled out two strips across the rings and cut it out with a utility knife...here's a pic halfway through the cutting..
[IMG]local://upfiles/6332/7DF0E74AABD7436E84BEB6B5E8547CAF.jpg[/IMG]
Old May 19, 2005 | 01:44 AM
Covz's Avatar
alright.. thanks sooooo much.. tell me how it works out when you mount it on your car
Old May 19, 2005 | 09:40 PM
BFlan2001's Avatar
they aren't really on yet, i'm waiting to clean my car until after the rain stops for good...i just stuck a small square of tape on the back and stuck it on to see how it looks...it's almost flush against the body even with the extra piece of tape on..i can see that there won't be any gap with just the one layer of tape...
NJ robb MN
Jan 22, 2009 03:59 PM
FezA4
B7 Models
Mar 12, 2008 06:40 PM
kemp_travis
Sep 27, 2007 03:24 AM
TT Tuner
May 26, 2004 12:57 PM
