BLEEDING- OVERHEATING?
Old Aug 3, 2005 | 10:36 PM
TUITETECH's Avatar
Default BLEEDING- OVERHEATING?
Hi,
I am new to the Audis, I a BMW E36 M3 owner... But I am helping out a buddy with his 1996 A4 2.8. quattro
It seems He decided to do a coolant flush, and refil with a "safe for all alumnium" engines coolant. YES, I know about the G12..... Thats another story.
But the problem is that after he flushed it then refilled it, The motor now overheats. after just 10-15 min of driving. From my experence, on previous porsches/BMW's I have owned the germans like to place bleeder screws in strange places. I did a search, but got a couple dead links. Do you guys Have a DIY link for complete flush and refill, and bleeding? It would be great!
Any toher tips would help to.
Thank you.
Old Aug 3, 2005 | 10:38 PM
TUITETECH's Avatar
Default RE: BLEEDING- OVERHEATING?
Just found this, Any pics of the Bleeder screws?
https://www.audiforums.com/m_109781/tm.htm
Old Aug 4, 2005 | 01:47 AM
rnbguy's Avatar
i need to find them screws too as ive done the flush and im getting overheating too... where are those screw peopleeeee i know jest knows but he must be busy....????????
Old Aug 4, 2005 | 12:24 PM
Asheldon21's Avatar
hello everyone!, i have a 1998 Audi A4 2.8 Q and just yesterday it started to run a little hot but not overheating, its about 3/4 or just under while driving and will not go any hotter.. i just had the water pump, belts, pulleys, Anti-frez replaced, a year ago i was told it might be the Thermostat going? does anyone have any ideas in what could cause this to happen?
Old Aug 4, 2005 | 01:10 PM
david9999's Avatar
Hopefully they replaced the thermostat when they did the water pump, didn't they?
If you weren't having problems with overheating before, take it to the shot that did the belt and get them to fix it.
Is your fan working?
If they did replace the thermostat, did they put it in backward?
Old Aug 4, 2005 | 02:32 PM
Asheldon21's Avatar
Do you know where the thermostat is located in the audi a4 2.8? i'm going to call the shop to day and ask for the paper work that was done on my car. thanks for your help
Old Aug 4, 2005 | 03:34 PM
david9999's Avatar
The thermostst should be in the water pump housing
Old Aug 4, 2005 | 03:38 PM
black991.8tq's Avatar
did u guys let the car warm up all the way without the raditor cap on?
Old Aug 4, 2005 | 03:54 PM
Asheldon21's Avatar
its been little over a year the water pump was replaced, this just started a few days ago. i'm not sure if they replaced the thermostat, i'm call ing to find out.
Old Aug 5, 2005 | 02:22 AM
rnbguy's Avatar
hey for the original enquiry as to how to bleed coolant system for 96-98 models without the bleeding screw here are the instructions on this site:
http://tech.bentleypublishers.com/th...threadID=18223
that guy knew his sh*t
ciao
oldmots
Jul 22, 2010 04:09 PM
upmysleeve
Sep 10, 2009 10:48 PM
germantech
Jul 17, 2008 03:05 PM
smoovmusicdj
Jan 16, 2008 11:48 AM
GT5 S
Nov 27, 2006 04:56 PM
