BLOW OUT!!! Coolant Temp Sensor
Old Nov 28, 2005 | 11:16 AM
quattrosedan's Avatar
Default BLOW OUT!!! Coolant Temp Sensor
Alright....I am starting to get F***ING P*SSED OFF. For the THIRD time in three months, my coolant temp sensor has blown out. WTF?!?! All three times I have replaced it with the correct clip from audi. I talked to a tech and he said that he has never heard of this. I don't know what to do. I am putting it on right every time, and it still blows off. The weird part is that it doesn't happen when Im in full boost either. It happens randomly at half throttle. So this time I ziptied that F***ING thing down. I want to see if anyone else has had this problem, and what they did. Thanks.
Old Nov 28, 2005 | 04:42 PM
GraffixWB's Avatar
Default RE: BLOW OUT!!! Coolant Temp Sensor
you might be one of the few that can get a new car due to the lemon laws. talk to your dealer. my buddy got a new evo 9 after his evo 8 , WITH PLENTY OF MODS, blew the water pump 3 times. talk to the dealer. Audi of america might hook you up
Old Nov 28, 2005 | 09:50 PM
AudiTech04's Avatar
ORIGINAL: GraffixWB
^Not a chance in hell
From the sound of it the car is out of warranty, thats why he is doing it himself
As for the problem, make sure the clip is on top of the ledge of the sensor
How long after you reinstall it does this happen
Old Nov 29, 2005 | 01:14 AM
like i said, maybe a month....and i dont drive conservatively. the wierd part is that it doesnt blow out when I am at wot, more or less when I am just daily driving it...and it has only happened three times in about three months. The audi tech thought I was putting it on wrong, so I showed him the third time, and he said I had it right, which I already knew, so now I have it ziptied. It isnt going anywhere.
Old Nov 29, 2005 | 04:44 AM
dankhound's Avatar
You may want to have your coolant reservoir tank cap checked for pressure. If the cap is plugged its posible it could hold to much pressure in the system causing repeated failures from a weak point in the system ie coolant tmep sensor.
Old Nov 29, 2005 | 01:41 PM
I already replaced it thinking that that was the problem...thanks for the idea though.
Nicram
Apr 8, 2014 08:47 PM
Brochacho
Apr 27, 2012 12:27 PM
stquattro
Jul 2, 2009 05:26 PM
