Boost drop and still no asnwer please help
Old Aug 13, 2006 | 02:47 PM
m5racer's Avatar
Default Boost drop and still no asnwer please help
ok guys i need your help on this. first my problem is that i have a giac chip and after 4,ooo rpm my boost slowly drops from 15 psi to 10 psi. i knwo that this is not normal. i need help beuase we tried eveything this weekend and the problem is still there. we checked the waste gate, the DV and even some little unit that controls the boost under the headers. and still no answer we lookd for leaks and couldent find any. i was wondering cold this be a leak that i just cant see? im doing a pressure test this week to make shrue its nto a leak but if it isent what could be doing this? please guys i need your hlp beuase my car has been liek this for a week.
Old Aug 13, 2006 | 02:57 PM
onepoint8tee's Avatar
Default RE: Boost drop and still no asnwer please help
It could easily be a leak that you cant see. Do the pressure test and let us know what happens.
Old Aug 13, 2006 | 10:35 PM
quattrosedan's Avatar
possibly a bad n75 valve... could be really anything. Definitely check for the boost leaks. Do you have a fmic?
Old Aug 14, 2006 | 01:05 AM
Slowb5's Avatar
still the ko3? even the sport cant keep putting out 15 psi,.....mine drops as well... its normal. unless its bogging and losing power.
Old Aug 14, 2006 | 01:50 PM
m5racer's Avatar
ya im doing a pressure test this week and was told by giac that its not normal for the pressure to drop at all. it should be 15psi all through the rpm range. im gonna see how the pressure test goes this week.
Old Aug 14, 2006 | 02:10 PM
brrman's Avatar
The psi will taper as the rpm's get high - anything over 5200 and the psi should start to fall off. 4000 rpm is fairly early - you are right in your sweet spot and the psi should hold at 15 at least for another 1000 rpm.
flipmode48
Oct 8, 2012 08:39 AM
krygods
May 31, 2010 11:45 AM
Quattro_1.8t
Sep 11, 2007 03:33 PM
EliteTuning1
Nov 27, 2006 09:12 PM
black991.8tq
Feb 17, 2005 01:05 AM
