Boost Drop??
Old Oct 7, 2012 | 08:43 PM
flipmode48's Avatar
Exclamation Boost Drop??
'01 A6 2.7T 95k....Not boosting as high as normal...the check engine light came on the other day, P1136 code said engine was running lean. I found a small vaccum hose leak near wastegate and fixed it today (CEL is still on though). Stock boost is normally around 8-9 psi, but I am only getting 6-7 psi. Also, the boost seems to climb more slowly than it has been, and it occassionally goes into limp mode (only 3-4 psi). The turbos were replaced about a year ago with all new blue hoses. There arent any other symptoms, no weird noises. Any ideas?
Old Oct 7, 2012 | 11:23 PM
A4S4Detroit's Avatar
I was having the same problem with my 1.8t and it was a plugged cat. Bought a test pipe and car runs great.
Old Oct 8, 2012 | 08:39 AM
flipmode48's Avatar
how do i test to see if a cat is plugged?
krygods
May 31, 2010 11:45 AM
Quattro_1.8t
Sep 11, 2007 03:33 PM
EliteTuning1
Nov 27, 2006 09:12 PM
m5racer
Aug 14, 2006 02:10 PM
black991.8tq
Feb 17, 2005 01:05 AM
