boost gauge help (pics)
Old Mar 9, 2006 | 07:02 PM
Dunzie182's Avatar
Default boost gauge help (pics)
so i've gotten my boost gauge to run 10Hg minimum and 10 boost peak...i know this still isnt right. i think ive done something wrong in the hookup, but cant figure it out for the life of me. heres some pics
http://putfile.com/pic.php?pic=3/6714563141.jpg&s=x10
http://putfile.com/pic.php?pic=3/6714585024.jpg&s=x10
http://putfile.com/pic.php?pic=3/6715015417.jpg&s=x10
in the last pic i attached the plastic tubing into the nylon and tied it off with a ziptie
Old Mar 9, 2006 | 07:04 PM
north5995's Avatar
Default RE: boost gauge help (pics)
Dude your pics aren't working.
Old Mar 9, 2006 | 07:05 PM
Dunzie182's Avatar
sry now they should be
Old Mar 9, 2006 | 07:15 PM
onepoint8tee's Avatar
ORIGINAL: Dunzie182
it has to be in the back of the gauge where the hose comes out.. Try unscrewing it and re seating the hose in there and use some locktite on the threads if you can..
Old Mar 9, 2006 | 07:20 PM
Dunzie182's Avatar
what do you mean by "it" and which picture are you referring too? plz let me know...im anxious to get this project over with
Old Mar 9, 2006 | 07:22 PM
dafrazi's Avatar
I would get rid of the plastic tubing and run good vacuum hose from the tee to the back of the gauge. Everything else looks OK. I think your probelm is either at the splice you made with the plastic tube or the compression fitting for the plastic tubing on the back of the gauge. You should be able to find the vacuum hose at any autoparts store.
Old Mar 9, 2006 | 07:30 PM
InsaneHatter's Avatar
DONT USE LOCKTITE.....
Its should compress fit if you screw it on right
Old Mar 9, 2006 | 08:40 PM
Dunzie182's Avatar
you were right defrazi...the plastic tubing going into the nylon was the problem...i taped it off right now as a quick fix but ill be buying some 6' vacuum hoses ASAP
superdooperme
Feb 7, 2009 02:30 PM
theguy1084
Aug 30, 2007 05:56 PM
airy52
Aug 18, 2007 03:01 PM
kraylon
Oct 6, 2006 01:12 AM
quattrosedan
Nov 24, 2005 11:05 AM
