Boost gauge light
Old Jan 4, 2006 | 04:09 AM
onepoint8tee's Avatar
Default Boost gauge light
I know i can tap into the red power line for the vents for the boost gauge light, but i saw that you cant tap into the black wire for the groud... Where is the best place to send the ground wire for the boost gauge light??? I can just put it on whatver i see that is metal right?
flyboy's Avatar
Default RE: Boost gauge light
Yeah, just check it with a test light first.
Old Jan 4, 2006 | 04:13 AM
Cool well ill have pics up tomorrow i was to busy to do it today, ill hopefully be doing the rear brakes this weekend..
Old Jan 4, 2006 | 01:35 PM
north5995's Avatar
If you are installing it in your center vent I just drilled a small hole in the back of the plastic vent tubing and fed the ground wire through down under the steering coloumn and attached it to some random bolt.
Old Jan 4, 2006 | 02:01 PM
aRIf's Avatar
any metal should do it.
at least this is what I did, and works just fine.
Old Jan 4, 2006 | 02:11 PM
ORIGINAL: aRIf
Cool!... Arif if your not busy this weekend you should stop by and check out the rear brake job ill be into... Plus, I could use more of that electronic buttton spray you had.. It didnt seem like it worked at the time, but about 2 days after you sprayed that stuff on my climate control buttons they seem to work a lot better, but not 100%... Well i should just get some of my own, but if you wanna check out the brakes and boost gauge let me know.
Old Jan 4, 2006 | 02:14 PM
aRIf's Avatar
Works for me but not saturday. My brother leaves saturday so I'll spend time with him then take him to the airport. If you do it on sunday, I'll be there.
Old Jan 4, 2006 | 02:28 PM
ORIGINAL: aRIf
Oh well i was thinking about doing it asap which would be saturday. Well actually i just hope the parts get here by then because they come from callifornia takes 3-5 days and they shipped yesterday... So hopefully ill get to do them this weekend.
Old Jan 4, 2006 | 03:24 PM
drkenan's Avatar
I assume by parts you mean the special brake tool required to turn those ******* pistons. I tried everything from needle nose pliers to that stupid brake cube they sell at autozone and nothing worked except for that tool that I had to order AFTER my wheels were already off. I'm sure you know this, but just a heads up.
Oh...and what is that electronic button stuff? I think I need some of that for my climate control too.
Old Jan 4, 2006 | 03:30 PM
ORIGINAL: drkenan
Oh, I have the cube thing from advance auto parts, that wont work????? Thanks for the heads up... That sucks.. Where did you order it from?
