Boost guage
Old Jan 23, 2007 | 10:01 PM
turbo kraut's Avatar
Tech Guru
Default Boost guage
so i went out and got an el-cheapo till the podi is made(i am planning on getting the borg guage or something better with it)
but i got a equassian or whatever from o'riellies
and when i hooked it up and tapped the vac line, it was garbage
so i bought a new vac line and threw it on, well
my car only boosts up to 5, maybe 6 and the needle shakes like a siv and makes a rattle noise, i don't ever see it drop, and at idle, it is in the grey at 20, will boost barely to grey 10, then 0 then 5/6, wondering if this is right? could it make noise cause it is cheap? did i do something wrong?
i am also throwing p0171 or whatever lean code is
could i be in limp?
any help would be great
Old Jan 23, 2007 | 11:27 PM
Jeff's Avatar
Zombie Defense Force
Default RE: Boost guage
where did you tap the line? cheep gauges done work. 5 sounds a bit low. but tahts becuase of the crapppy gauge probably.
Old Jan 24, 2007 | 01:51 AM
Tech Guru
i tapped about mid way
so cel shouldn't be making me go limp mode?
Old Jan 24, 2007 | 02:01 AM
Jeff's Avatar
what hose did you tap?
Old Jan 24, 2007 | 03:51 AM
Dj Spiel's Avatar
has same issue was boosting 5psi......
re-wire gauge check all connections
I have k03 boosting at 7psi
(NO ENGINE MODS)
ORIGINAL: turbo kraut
could i be in limp?
Old Jan 24, 2007 | 04:02 AM
onepoint8tee's Avatar
tap into the vac line on top of the intake manifold on the radiator side instead of the vac line on the FPR just incase you didnt try that.
Old Jan 24, 2007 | 01:49 PM
Tech Guru
there are some pix
Old Jan 24, 2007 | 01:51 PM
Tech Guru
blah
Old Jan 24, 2007 | 01:53 PM
Tech Guru
got it
J.BivensA4
Apr 18, 2010 12:19 PM
xA4x
Aug 20, 2007 08:42 PM
randomloginname
Jan 13, 2007 04:34 PM
dafrazi
Sep 7, 2005 10:10 AM
active1331
Apr 18, 2004 05:41 PM
