Boost Guage Installed
Old Feb 22, 2007 | 03:39 PM
Stuntman's Avatar
Default Boost Guage Installed
Installed boost guage today. Took a hole 1:30. Nice an clean install to.
Im boosting 6psi in 1st, and 7 psi 2nd-5th. vac is 10.5 solid.
Ready for Chip/DV now
Done so far : Air box mod w/ K&N. 4 new tires. Boost guage.
Old Feb 22, 2007 | 03:45 PM
Sp33d07's Avatar
Default RE: Boost Guage Installed
you will be suprised when you see your boostgauge going crazy after you get chipped i spike around 19 psi mabe 1psi more or less some times but its nice to have a boostgauge knowing that air is flowing without leaks
Old Feb 22, 2007 | 04:10 PM
acetrebo's Avatar
You say nice clean install, but...
Old Feb 22, 2007 | 04:12 PM
Soley4pres's Avatar
what are you idling at in hg? just curious... anyone else with a boost guage installed and chipped have a different idle in hg?
Old Feb 22, 2007 | 04:15 PM
MissionCtrl's Avatar
yeah vac should be about 20 at idle
Old Feb 23, 2007 | 12:55 PM
Stuntman's Avatar
You say vac is suposed to 20 at idle? Ill test it with vac guage tester. As for Pics. Gota get a new usb cable for camra. Ill have em up soon tho.
Old Feb 23, 2007 | 01:09 PM
Amze's Avatar
Sweet deal man, boost gauges are awesome
Is yours like the podi one or is it in the dash?
Old Feb 23, 2007 | 02:28 PM
Stuntman's Avatar
Its a cheap guage. Nothin pretty. Its a faze, pod. Mounted on dash, left of steering wheel. I plan on dumping all my xtra money on the motor. All go. no show. My vac tester is pulling 10.5 hg from the T split. So I know its not my install. Boost is consistant. vac is low. Any ideas?
Old Feb 23, 2007 | 03:02 PM
smokeU's Avatar
looks good!
Old Feb 23, 2007 | 09:39 PM
turbo kraut's Avatar
Tech Guru
which hose did you hook it up to? front or rear(fpr)
and where in that hose?
mine is at 20 and i am in the middle of the front hose
