boost leak?
Old Oct 20, 2006 | 01:46 PM
EliteTuning1's Avatar
Default boost leak?
ok so i found a huge hole in my breather hose wich is connected to the inlet, and i thought for sure that would be my solution for my loss in power. so i bought a stronger tube from purems.com and put it on but my car still doesnt seem to be as fast as it used to. do you think i have a problem with my chip or another boost leak somewere. its a 2001 a4 1.8t, giac-x chip
Old Oct 20, 2006 | 01:51 PM
CRAZYHAWK's Avatar
Default RE: boost leak?
Do you have a CEL?
Old Oct 20, 2006 | 02:20 PM
smokeU's Avatar
check all hoses. especially the l-hose near the intake manifold. do you have a boost gauge? what psi are you running?
Old Oct 20, 2006 | 04:33 PM
thanks man,
i actually found a small slit in the that l-shaped tube. i taped it up and saw a huge performance gain. i can hear the boost leaking out of the tape but after my car cools ill do a better tape job and see if it still leaks
to4xxx
Jun 8, 2012 11:56 AM
onepoint8tee
Jun 27, 2007 04:38 PM
truckjunky87
Feb 8, 2007 12:33 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
a4bsix
Jul 6, 2006 04:28 PM
