Boost Logs/Boost leak tester pics UPDATES
Ok one free boost leak test for one free check valve [8D]
I wouldnt be surprised if my temporary fix lasts a while though. It is some advanced jigger rigging on my part
I didnt break it!!!!!
ORIGINAL: aRIf
also the crap you broke,
Here is a new log of requested boost vs. actual with the MBC installed (eliminated the n75). Help me make some sense of this, perhaps another nifty graph x1rider ?
Boost is going to be more all over the place at part throtle/engine load because the boost controller isnt working refering to a map of specified boost anymore. The main thing I am worried about is requested vs. actual boostat wot/max engine load. As far as fault codes/limp mode goes, I STILL get the 17964 - Charge Pressure Control: Negative Deviation fault code, but now does NOT go into limp mode from it. Im guessing that has something to do with the N75 being bypassed.... But the fault code and #'s still indicate lower than requested boost at WOT, so if there are no leaks, Im guessing it might just be a tired turbo or something else I havent thought of.. Here is the link for the logs: http://putstuff.putfile.com/91039/4804233 Thanks for any feedback on this.
