Boost Logs/Boost leak tester pics UPDATES
Old Jun 26, 2007 | 03:49 PM
  #31
dafrazi's Avatar
Default RE: Boost Logs
When graphed, you are siginificantly under requested boost during in what looks like 4th gear of your first run and slightly under requested boost for the rest of that run. On your second run you are over requested boost formost of the log.
To make a graph in excel, cut and paste your data into excel. Click on the insert menu and select chart. Select the "line" for chart type and select the left most option foron the first or second row (you will see a pink and blue line which interesect about half acroos the chart). Click next and thenselect (click the upper left most datacell and drag to the lower right cell)your actual and requested boost readings. Then click the series tab at the top of the chart window. Look at the bottom of the chart window you will see "Category (x) axis labels:" click inside the white box and select the rpm data (click and drag). Click the finish button and you should seea graph of your actual vs. requested boost over the rpm range.
Your log looks pretty normal. You will neverget actual and requested to match perfectly. Some under boost and over boost is normal. Try logging the MAF readings, O2 readings and boost readings together and posting them. We may be able to see what is going on with all the data presented together.
Old Jun 26, 2007 | 04:25 PM
  #32
acetrebo's Avatar
Looks to me like you have overboost when turbo is in its best operating range, between 3000-5000, then actual starts to drop of in the higher rpms as your turbo becomes less efficient.
Did you ever log anything before with the other race valve, just to compare? Id say it looks pretty normal, your just hitting the limits of the old stock K03.
Old Jun 26, 2007 | 05:28 PM
  #33
onepoint8tee's Avatar
Thanks for the info... No, I never logged boost with the race valve because I never had any obvious issues with it like I did with the stock n75. Everything seems great though driveability wise now. Boost comes on stronger and full boost is reached much sooner, yet it is still smooth. Im just glad its not going into limp mode anymore. Here is a pic.. Sort of stealthy and easy access:
You can read about it here:
Old Jun 26, 2007 | 05:34 PM
  #34
cincyTT's Avatar
I'm make believe
pretty nice piece for $22 wouldnt you say? I think so.
Old Jun 26, 2007 | 05:49 PM
  #35
ORIGINAL: cincyTT
Yup, like you said, other than the tacky sticker, its a quality product. Im super impressed with it. There is no surging, or anything bad about it. The only difference now is full boost is reached probably 500-700 rpms sooner and if there are spikes, Im not noticing them. My driving enjoyment has just been bumped up a few notches. Its set to about 18/19 psi, Id try to bump it up to 20 but the **** feels very lose if I increase it any further.
Old Jun 26, 2007 | 07:24 PM
  #36
x1rider's Avatar
Old Jun 26, 2007 | 09:13 PM
  #37
Thanks
Old Jun 27, 2007 | 04:04 PM
  #38
acetrebo's Avatar
Sweet!
A-racing we will go,a-racing we will go, on out to kirkersville, a-racing we will go!
Can't wait for next friday the 6th, gonna be lots of fun!
Old Jun 27, 2007 | 04:09 PM
  #39
aRIf's Avatar
no it's a scam. I paid him2 tylenosand he could not even test my system
Old Jun 27, 2007 | 04:38 PM
  #40
ORIGINAL: aRIf
HAH! Maybe we can get someone to explain why when we hooked it up to your engine and pushed air though it made that dripping sound from around your turbo???
ORIGINAL: acetrebo
Yup, I hope its not too hot though.
riydan
Sep 3, 2010 07:45 AM
flynnr
Mar 2, 2010 07:24 AM
flynnr
Feb 15, 2010 12:22 PM
integrosse
Sep 16, 2008 08:17 PM
tooxtreme8813
Aug 24, 2006 03:32 AM
