boost loss problems
so i have a giac chip and i notice that when driving pretty hard atabout 5,000RPM i notice the boost drop from 15psi to 10psi. is this normal? if not what could the problems be? everything else seems to be normal. idle's at -20vac and doesent bounce or anything and doesnt spike over 20 and settles at 15 psi. is this drop normal or could there be a broblem
check the corner of the L hose located near/behind the manifold. a hole can develop in the corner and cause those symptoms. over time the hole will get bigger. i just replaced mine. theres a thread I posted a few lines down.
Sounds like you are going into limp mode at wot at redline. get scanned for codes. This exact thing happens to me from time to time. goes out of limp mode when i restart. i hardly ever go to redline, so its hardly ever a problem for me. but i always get a negative deviation fault code with it.
Since i replaced my DV and DV vac line i have not noticed this though and i have gone to redline in wot a couple times since then i think.
ya my L hose alrady ripped about a week ago. this seams to be my second boost leak. to take it out of limp mode can i just unhook the battery for liek 10 minites or does it have to be scanned and cleard by vag...thanks
ORIGINAL: m5racer
my car is an 01 and i dont have vag but a firend of mine does. and im pretty shure its a boost leak cuaseitsbeen liek thisfor acoupple of days now. and even when at idle and with all windows closed and no radio on i can hear a nice little wistleing that soundsliek the turbo but the turbo isent very loud at idle so im pretty shure its a boost leak. i hate this leak ****. also i can feel the diffrence at lower speeds also beucase i noticed my DV doesent blow off any morein 1stgear unlessi almost floor it.
are you saying you cant hear the turbo recirculate but only in 1st gear when you let off the gas?? thats pretty normal. DV's arent loud like BOV's unless you have an intake mod and even then its not as loud as a BOV. And if you have tiptronic its even harder to hear because when you switch gears the throtle plate doesnt close like in a manual where you let off the gas entirely between gears and the throtle plate fully closes which is when the boost is recirculated through the DV and into the intake.
Its very difficult to diagnose a boost/vac leak over the internet.. Pick up your ***** and go to home depot and buy the parts to make a boost leak tester!!!
