Boost Problem?
Old Jun 6, 2005 | 10:12 PM
a4fanatic82's Avatar
Default Boost Problem?
My 2002 A4 1.8TQuattro Tip seems alot slower than usual for some reason. I hear this really high pitched whine coming from the engine all the time, is this a leak maybe? or just the sound the turbo makes? It is supposed to run 0-60 in 8.5 (which is pitiful itself) but its even worse than that, its over 10 seconds i swear. There is little response in first gear when i put it down to the floor, second is a little better, but it just seems alot slower than what it used to be. DV problem maybe? but i don't hear any chirping, and my car isn't chipped so i don't see why it would be that. Any help would be greatly appreciated. thanks!
Old Jun 6, 2005 | 11:45 PM
Jestnomen's Avatar
6th Gear
Default RE: Boost Problem?
A whistle sound can indicate that your diverter valve is failing. You may also have a vacuum hose leak.
Old Jun 7, 2005 | 12:48 AM
i'll go to the dealership and get a 710N DV then and see what happens, thanks!
Old Jun 7, 2005 | 12:49 AM
where is the vacuum hose at?
Old Jun 7, 2005 | 01:12 AM
Jestnomen's Avatar
6th Gear
There is more than just one. If you look in your engine bay you'll see a bunch of them.
Old Jun 15, 2005 | 04:00 AM
BadBlueB5's Avatar
Check the fat turbo hoses . . if there is a leak you will be able to hear it with like a ffuuuuuiisshhhhssss, vacum leaks are a bit trickier, now if you are still having problems detecting the leak, try a soapy solution at the joints of the turbo hose, if you see bubbles there is your leak.
Good Luck
audia4boy24
Jul 26, 2008 11:03 PM
dgirlsdemsugar
Jul 21, 2007 09:28 PM
eurotech
Apr 5, 2006 02:18 AM
Dieselboywu
Jul 24, 2005 02:11 PM
active1331
May 23, 2005 09:15 PM
