boost problem
Old Apr 4, 2006 | 07:12 PM
eurotech's Avatar
Default boost problem
i have a 98 a4 1.8t when you drive down the road the boost spikes to 10 psi and then falls to 4psi. there are know codes in the ecu. i runs like its going into limp mode. heres the thing, if i power brake it it will spike 10psi and hold it all day( if i held it that long). the duty cycle while power braking is 100 percent and that means 10 psi. while driving the duty cycle goes to 5 percent and the means 4 psi.... any help would be appreciated. by the way its all stock!
Old Apr 4, 2006 | 08:05 PM
onepoint8tee's Avatar
Default RE: boost problem
Could be a bad wastegate or n75 valve.
Old Apr 5, 2006 | 01:26 AM
xx18quattroxx's Avatar
wastegates are fun to replace id rather shoot myself than do that again
Old Apr 5, 2006 | 02:18 AM
duhvinci's Avatar
It almost sounds like an issue that has been discussed before:
https://www.audiforums.com/m_233990/.../tm.htm#234119
My solution was MBC, almost 3 months and still no more boost loss issues...
D
audia4boy24
Jul 26, 2008 11:03 PM
dgirlsdemsugar
Jul 21, 2007 09:28 PM
a4intec
Oct 27, 2006 03:43 PM
Dieselboywu
Jul 24, 2005 02:11 PM
active1331
May 23, 2005 09:15 PM
