boost problem
Old Apr 27, 2007 | 11:53 PM
mikejda's Avatar
Default RE: boost problem
cool thanks alot I'll try that out and see what happens.
thanks again
Old Apr 29, 2007 | 07:10 PM
mikejda's Avatar
ok finally got a vag-com and this is what I got.
Bank 1 system to lean now what?
Old Apr 29, 2007 | 07:14 PM
onepoint8tee's Avatar
There are several different lean codes. What is the exact fault code?
Old Apr 29, 2007 | 07:16 PM
mikejda's Avatar
brb going to autozone to get the number
Old Apr 29, 2007 | 07:33 PM
Just FYI, you didnt "get a vag com"... You "went to autozone so they could use their generic OBD II code scanner." Vag com is diagnostic software used with a laptop that does much more than just read fault codes
Old Apr 29, 2007 | 08:07 PM
mikejda's Avatar
ok this is what I have
PO-171
Guy said something about fuel system is lean help!! thanks
Old Apr 29, 2007 | 08:11 PM
Thats the fault code i had when my maf went bye bye. Try cleaning it with nonaproxyl ( ****! cant remember how to spell it) alcohol and fine bush tooth brush. Youll have to take the top of the airbox off to get to the maf sensor, which involves disconnecting a few obvious things connected to it.
Old Apr 29, 2007 | 08:16 PM
  #18
mikejda's Avatar
thanks for your help I'll give it a shot.
And you last question is the MAF located inside the airbox right below the filter if you where to remove it?
Old Apr 29, 2007 | 08:18 PM
  #19
Its right above the filter. You dont even need to take the filter out... Just the top part of the airbox, and the maf will be secured to the top inside.
Old Apr 29, 2007 | 08:24 PM
  #20
mikejda's Avatar
thanks again. I don't how much money i have saved from this website. This website is the sh*t thanks
audia4boy24
Jul 26, 2008 11:03 PM
dgirlsdemsugar
Jul 21, 2007 09:28 PM
eurotech
Apr 5, 2006 02:18 AM
Dieselboywu
Jul 24, 2005 02:11 PM
active1331
May 23, 2005 09:15 PM
