Boost Question
Old Jan 30, 2007 | 05:20 AM
drs305's Avatar
Member
Default Boost Question
I bought a 01' A4 1.8t this past summer and the guy I bought it from said it had a chip in it but didn't tell me which one. Anyway, I installed an APR boost gauge this weekend and I am getting some weird readings. Right after I installed the gauge I noticed that I couldn't get more then 5 or 6psi and was pissed knowing a chipped Audi should run 12 to 14psi. Later on in the week I took a long drive and started boosting approx. 14psi mostly in 4th and 5th gear. I then figured out if I let go of the gas in 5th gear and then press on it again the boost would go up to 14psi and hold; my car has never driven like this and the gauge helped me understand how to get this extra hp (power is sick!). The next day I took my car out and couldn't get it to go past 5/6psi in lower gears and still have to let go of gas and the repress it in higher gears to get the power (most of the time). Does anyone else have this same situation with their chipped A4? Are there any possible problems? Why does my turbo not hold a constant boost level? Thanks.
Old Jan 30, 2007 | 11:29 AM
sirfalconx's Avatar
Default RE: Boost Question
Not really sure what’s wrong, my car holds 19/19.5psi consistently through all gears. One time when it was 7 degrees out, it surged to 21psi but it hasn’t happened again since... Maybe it’s a bad/cheap chip? But, I would think if it was mechanical you would never hit 14psi… Its not hard to check the chip is pretty easily accessible, might want to take a look… It could be the stock DV too, but I don’t know much about that because mine was already replaced when I got mine…
Old Jan 30, 2007 | 03:27 PM
drs305's Avatar
Member
How do I test if the chip is bad??
Old Jan 30, 2007 | 03:28 PM
techbod's Avatar
data logging with VAG or rolling road mate
Old Jan 30, 2007 | 07:07 PM
drs305's Avatar
Member
Does anyone have the same boosting issue? How do I find out which chip my car is running? How much is a VAG?
Old Jan 30, 2007 | 07:15 PM
new2me's Avatar
My car boost about 12-15psi till 3rd then its about 20psi till 5th.
Old Jan 30, 2007 | 07:20 PM
akielb's Avatar
I know this might sound like a PITA but take out your ECU and open it up - to see if it is really chipped - post a pic of the inside if you can't tell.
Old Jan 30, 2007 | 10:37 PM
ryansonfire's Avatar
you know my car did the same thing fora week, i upgraded the dv and it never did it again. maybe the dv is not venting and your wastegate is left open. give it a try, but what the hell do i know?
Old Jan 30, 2007 | 11:37 PM
Lazer Viking's Avatar
make sure your boost gauge is hooked up tight, might have a leak or something
and + 1 on cracking open the ecu to find out which one
Old Jan 31, 2007 | 12:05 AM
brrman's Avatar
ORIGINAL: ryansonfire
I would second the DV. Replace it.
