boost Vag-logs with new chip
Old Sep 16, 2007 | 09:13 PM
pfeifstudd's Avatar
Default boost Vag-logs with new chip
I did some Vag Logs after i got my new chip last week and i got these. It seems like alot of boost, i mean it halls, but am i doing the math wrong, the conversion i used it listed at the top as 1mb=0.0145psi. This was a quick burst through i think the first three gears. its a 2004 1.8t ultrasport, with just a chip.
[IMG]local://upfiles/39785/9CBFA0928D9647A0A8503D958AA5A836.jpg[/IMG]
[IMG]local://upfiles/39785/3C29A2A6791C4AA6978E1FDADF3A9D94.jpg[/IMG]
Old Sep 16, 2007 | 09:18 PM
onepoint8tee's Avatar
Default RE: boost Vag-logs with new chip
You have to factor in outside atmospheric pressure which is 14.7 psi (at sea level). Also its best if you paste your data into an excell spreadsheet format instead of notepad so we can see columns that are easy to read.
EDIT
Ya, like that^
So where you see 30psi, its more like 15 psi when factoring atmospheric psi. Next mod, boost gauge!
Old Sep 16, 2007 | 09:24 PM
pfeifstudd's Avatar
i still have the stock DV and am getting a Forge unit tomorrow, what affect should that new DV have on these numbers if any? and do these look pretty normal for chipped but otherwise stock car?
Old Sep 16, 2007 | 09:35 PM
Looks normal from what I can tell. You wont notice a difference between DV's unless your stock one is bad.
TurboFick
Dec 26, 2012 05:44 PM
Rn3037
Apr 21, 2010 09:26 AM
DanPHines
Oct 16, 2009 08:04 PM
TeeterTawter
Jul 29, 2007 12:13 AM
onepoint8tee
Jun 27, 2007 04:38 PM
