BOV?? :-(
Old Apr 11, 2004 | 11:33 PM
apexiA4's Avatar
Default BOV?? :-(
I have a blow off valve that came on my car, so does that mean my s**ts gonna explode <IMG src=smileys/smiley11.gif border="0">
Old Apr 12, 2004 | 12:36 AM
Jestnomen's Avatar
6th Gear
Default BOV?? :-(
Most likely your car will spontaneously explode. Did you read the sticky thread?
Old Apr 12, 2004 | 12:40 AM
apexiA4's Avatar
Default BOV?? :-(
aww f**k. really? what are the chances? I mean, I sounds like a BOV but it could be the intercooler? or maybe the new air filter thats hooked into the turbo input? I need to get this s**t checked out. f**k. <IMG src=smileys/smiley7.gif border="0">
Old Apr 12, 2004 | 12:43 AM
Jestnomen's Avatar
6th Gear
Default BOV?? :-(
well no not "spontaneously" but it's not very healthy for your car. I have a naturally aspirated engine so I don't know the specifics.
Old Apr 12, 2004 | 01:12 AM
apexiA4's Avatar
Default BOV?? :-(
well, you guys think if i just go easy on it until i can get it checked out it shud be aight?
Old Apr 12, 2004 | 03:46 AM
SlimChriz's Avatar
Default BOV?? :-(
should be alright it takes a while for it to destroy your engine just get it checked. </P>
youl probly have problems like stalling if you have a BOV it might be a hybrid which is a cross between bov/dv in that case it might be alright</P>
Old Apr 12, 2004 | 02:35 PM
brrman's Avatar
Default BOV?? :-(
You are not recirculating your unused boost. Bad for car cuz it is now not getting enough air in the air/fuel mix - which means you are running rich. Will eventually clog cats and ruin your maf, oxygen sensors, etc...
Remove the BOV and put on a BPV.<edited><editID>brrman</editID><editDate>38089.4837152778</editDate></edited>
Old Apr 12, 2004 | 08:07 PM
active1331's Avatar
Default BOV?? :-(
i had a bov on my last a4 and it ended up messing up the electronics in the car and i had to do a lemon law with it.</P>
Old Apr 12, 2004 | 09:54 PM
apexiA4's Avatar
Default BOV?? :-(
well where cani get a BPV, and how much
Old Apr 13, 2004 | 04:46 AM
brrman's Avatar
Default BOV?? :-(
a decent BPV can be found almost at any Audi performance site. A common choice is the TT 225hp (known as the 710n) BPV. Cost like 30 bones.
It will probably eventually die on you in a couple years if you are chipped. Ive had mine for a year and its starting to go I think.
Other more solid (metal constructed) choices are Baily, Forge, Hyperboost...those go for about $125-$150
