Which BOV should i use? haha J/K but look
Old Apr 17, 2007 | 03:17 PM
BaconBait's Avatar
Default RE: Which BOV should i use? haha J/K but look
From what I've come to understand recently, on 00+ VW/Audi motors you can use a 50/50 DV or a BOV. Because the 00+ have an air pressure sensor after the DV/BOV. The ECU still has to adapt, but it's not nearly as bad as running a BOV on a pre 00.
In my opinion, the only good BOV on an Audiis one with a duck call or a built motor.
Old Apr 17, 2007 | 03:48 PM
patty AT forge's Avatar
ORIGINAL: Jovian
So its only at idle that it its taking note? If thats the case you just block off the joint and use a regular BOV since at idle there should be nothing going through anyways becuase there is not enough pressure to open the DV valve. That doesnt make sence to me.
However, there is enough vacuum to open the valve.
Old Apr 17, 2007 | 04:05 PM
chaos92287's Avatar
ORIGINAL: patty AT forge
bingo
and im thinkin about running a BOV once i go BT. if i do i gotta try thishttp://videos.streetfire.net/categor...62DAE06131.htm
Old Apr 17, 2007 | 04:44 PM
nickellis14's Avatar
dear lord, onpoint8tee must be having a heart attack right now! a post with people who are actually using BOV'S!!!!! ridiculous! HAHA!!!
good info guys. I'm still inclined to recirc mine 100%, as I still haven't heard a good reason not to. anyone got one?
Old Apr 17, 2007 | 04:46 PM
BaconBait's Avatar
You'll sound like a ricer.
Old Apr 17, 2007 | 04:53 PM
hmmm....yeah, sounding like a honda doesn't really appeal to me....anyone got a better reason than that?
I don't get it. why wouldn't you want to sneak up on people and then beat the bag out of them?? with your DV blowing off into the air you're just saying "look at me!!! I've got mods under my hood!!!" sounds like these people watch to much "fast and the furious". why why why do you want your engine to make MORE noise! this is a high end car! the point is, its quietly agressive and fast. if you want a rice rocket save yourself $15,000 and buy a civic!
Old Apr 17, 2007 | 04:56 PM
onepoint8tee's Avatar
ORIGINAL: nickellis14
Good boy!
Old Apr 17, 2007 | 09:51 PM
  #18
cincyTT's Avatar
I'm make believe
ORIGINAL: BaconBait
All map'ed equiped cars.
Old Apr 17, 2007 | 09:57 PM
  #19
cincyTT's Avatar
I'm make believe
ORIGINAL: widgget
I have a GFB Hybred D-BOV. Strightup if you are venting ANYthing out your engine will run rich end of story. Even at 10% blowoff at high revs i still throw codes indacating that there is a lack of fuel, not to mention i can see it running rich by monitoring the blocks in VAGCOM. the bottom line it is bad for your engine, save yourself the money and get a nice DV. I personaly have found the sound of a K04 spooling up much more pleasing then the pshhhhh sound anyway, after awhile it just sounds like a tractor trailers air breaks.
you bought a gfb, you should complain. [:'(]
Old Apr 17, 2007 | 10:10 PM
  #20
Jeff's Avatar
Zombie Defense Force
yes i will be testing this bov dv what ever you want to call it. i will be testing on the evo but we also run a maf and encounter the exact same problems. forge ftw
Emilgevor
Feb 18, 2009 11:03 PM
teru23
Mar 25, 2006 04:25 AM
raider
Nov 15, 2005 09:33 PM
18T
Sep 18, 2005 07:12 AM
Jestnomen
Mar 30, 2005 09:14 PM
