Brake Fluid DOT3 and DOT4 ?????
Old May 24, 2005 | 11:30 AM
juju4uofa's Avatar
Default Brake Fluid DOT3 and DOT4 ?????
I changed my brake pads and filled my resovoir back up with DOT3. I just had to change my rear PS caliper and I noticed before I bled my system the resovoir says DOT4 only. Well, I didn't put any more DOT3 in it, however, I do have about 10 ounces of DOT3 mixed in with the fluid. Is this going to cause problems or will I be okay. I hate to flush my system but if need be I will. Thanks!
Old May 24, 2005 | 11:34 AM
Jestnomen's Avatar
6th Gear
Default RE: Brake Fluid DOT3 and DOT4 ?????
I would not risk having mixed brake fluid in there.
Old May 24, 2005 | 11:58 AM
CheckMyVitals's Avatar
yeah man, brakes are definatly not something you wanna be messing around with. you're gonna wanna flush that. after all... what's the only way you're gonna find out if your brakes are working?
Old May 24, 2005 | 12:32 PM
CRAZYHAWK's Avatar
We are supposed to change the brake fluid every 2 years any-way.
Old May 24, 2005 | 05:56 PM
BFlan2001's Avatar
it's not going to do any damage, it's not a big deal, the only difference between the two fluids is the boiling point. i've mixed the two fluids many times (mostly in motorcycles, but the systems are the same)
Old May 25, 2005 | 03:16 AM
headshok2002's Avatar
yeah its dot 5 that is drastically different from 3 and 4, I believe... I've heard mixing the 2 is fine -- wouldnt want it in my car... but whatever.
Old May 25, 2005 | 03:21 AM
BFlan2001's Avatar
yes, you definitely do not want to mix dot 4 and dot 5 fluid, that will basically ruin your whole brake system (one is glycol-based and one is silicon-based)
HeyCesar
Apr 19, 2013 05:39 PM
B5 Audi
Nov 27, 2009 05:24 PM
AR15Texan
Jun 10, 2009 12:24 PM
jakej
Nov 12, 2008 08:55 PM
