Brake Job
Old Nov 24, 2006 | 01:09 AM
tractioncontrol's Avatar
Default RE: Brake Job
They say to open the bleeders to make returning the piston easier. If the pins aren't pitted or rusted or damaged in any way they should be just fine.
Old Nov 24, 2006 | 03:27 PM
duburban's Avatar
So i'm starting to do the rear and i can't get my wheels off. I've tried one side but its stuck on there. There's only the 5 wheel bolts right? Anyone have a remedy?
Old Nov 24, 2006 | 03:50 PM
ProOnThaSnow's Avatar
Kick the outer edge of the tire, hard. It should pop the wheel loose from the hub.... they like to stick sometimes after being on there a while.
Old Nov 24, 2006 | 10:12 PM
TheJazz7's Avatar
Yeah, just pull on that sucker, it'll come off. You can try loosening it with a hammer, just put a 2x4 around the edge of the wheel and smack the wood, not the wheel itself (duh)
Old Nov 27, 2006 | 12:40 AM
duburban's Avatar
I finished the rear rotors and pads today. In the process i snapped a bolt off but i managed to vice grip out the remainder and throw in a new bolt. Great experience over all and im ready to go after some bigger things. Thanks for all your advice!
Old Nov 27, 2006 | 12:49 AM
acetrebo's Avatar
Congrats on completeing DIY 101.
Your ready for DIY 201.
Hmm.... what do you need next? T-belt change? Tie-rod ends? You'll be ready when the time comes!
Old Dec 18, 2006 | 11:00 PM
duburban's Avatar
Going back in! I want to re-do somethings i should have done the first time.A few questions... What should i use to clean the brake caliper hanger? Sandblast neccesary? Steel wool? Some sort of liquid? And how much anti sieze should i put on the back of my brake pads to keep them from squeeking. I really want to do this RIGHT, so any tips and small details would be awesome.
abc27
Aug 25, 2013 04:19 PM
NorthernComfort
Sep 19, 2007 07:54 AM
