Brake lights not the dash board brake light.
Old Jan 22, 2016 | 08:47 PM
Jbakes's Avatar
Default Brake lights not the dash board brake light.
I recently repaired the light switch on my 96 A4 and when I took it for a test drive I noticed that my my brake lights were partially on and when I step on the brakes that my parking lights also come on. This was not happening prior to the light switch going bad. Anyone come across or hear of this problem before?
Old Jan 25, 2016 | 11:26 AM
rhodes991's Avatar
I would make sure the repaired light switch was repaired correctly. Make sure any wires are in the correct spot and tight. Since this only appeared after the repair that is the best place to start. Not sure of the cost, but a new light switch might be called for.
Also, not sure how brake lights can be partially on. Did you mean the tail lights were on?
nize
Jun 21, 2013 01:16 PM
skyz
Nov 26, 2008 07:29 PM
Tizer
Mar 12, 2006 08:25 AM
Dj Spiel
Aug 25, 2005 04:08 PM
Daveo
May 3, 2005 11:35 PM
