Brake Pads and Rotors
Old Nov 10, 2011 | 07:16 PM
ss5489's Avatar
Default Brake Pads and Rotors
Im new to this forum but i really need serious help... I went to the shop because my brakes were grinding and the mechanic said i need new brake pads and rotors.. he said he could turn the rotors but it will still make noise... anyway i wanted to get the opinion on which are the best brake pads and rotors for the audi like brand and such... thank you
Old Nov 11, 2011 | 01:00 AM
ss5489's Avatar
can i get help!!!
Old Nov 11, 2011 | 07:09 PM
B7Night's Avatar
My fronts needed replacement at about 73,000 miles. I just replaced mine with genuine Audi pads and rotors. The little brake pad warning symbol should trigger long before you grind the brakes. At least it did on both my 2000 Jetta and 2006 Audi A4. It was a little over $ 400. Pricey probably, but at least the brakes behaved the same afterward. No drastic change like can be experienced by changing brands.
Old Nov 11, 2011 | 09:59 PM
ss5489's Avatar
thanks no light has come on but i do hear grinding
Old Nov 12, 2011 | 07:47 PM
hxgaser's Avatar
It all depends on what you are looking for. If you ask 10 people for opinions on brake setup, then you may get 15 answers. Anyways, for my spirited driving, but not racing in anyways, I like Hawk HPS pads. If you are looking for less dust, then go for a ceramic pad set. FYI, I would recommend that you get new rotors while at it. Blank rotors are not that expensive. No need for drilled or slotted rotors unless you like the look.
Old Nov 13, 2011 | 04:07 AM
ss5489's Avatar
thanks for the help
Old Nov 14, 2011 | 12:52 AM
Clos2010's Avatar
Brake motive on ebay has full set front & rear cross drilled and slotted rotors w/pads for under $200, the feedback sounds good. You might wanna check them out.
sbaer2
Mar 5, 2013 11:06 AM
Kealoha3
May 20, 2010 04:43 PM
jsc4321
B7 Models
25
Mar 8, 2010 09:55 PM
QuattroSD
Nov 6, 2007 04:50 PM
ebang
Aug 12, 2004 11:59 AM
