Brake ?'s - OEM friction material and manufacturer
Old Jun 18, 2013 | 11:37 PM
Mossyoakglock's Avatar
Default Brake ?'s - OEM friction material and manufacturer
I have a few questions on the A4 brakes, specifically 2005.
First question: what is the factory friction material? Is it Semi-Metallic or Ceramic? According to RockAuto.com, Semi-Metallic is OEM.
#2: Who makes the OEM brakes? I was looking on ECStuning at the OEM brakes and you can clearly see Akebono stamped on one of the ears. Rockauto also says that they are the OEM supplier.
I was tying to do some research and there was somewhere that said after a certain year, Audi went to ceramic brakes instead of Semi-Metallic. Is that the case?
Old Jun 19, 2013 | 10:31 AM
rhodes991's Avatar
On my 2008 they were semi-metallic. There is some debate what is OE and what is OEM. To me OE is what came from the factory while OEM is made to the same specis as what came from the factory. In other words if Akebono supplied some OE brakes then brakes bought from them (not through Audi) would be OEM. OEM to means as good if not better than factory.
Wouldn't be surprised if the S4 had ceramic brakses and possible some of the newer model A4s as well. Less brake dust with ceramic.
Mossyoakglock
Jun 18, 2013 11:32 PM
dannob
Aug 27, 2011 01:25 AM
Freight_Cartel
Feb 28, 2011 07:14 PM
RedShoeRider
Jun 20, 2008 04:38 PM
BLK_A4
Oct 19, 2007 02:43 PM
