spring bolt on rear brake causing constant pad friction
Old Feb 28, 2011 | 06:40 PM
Freight_Cartel's Avatar
Default spring bolt on rear brake causing constant pad friction
while replacing my rear brakes on my 2001 1.8L a4 one of the two spring bolts that hold the caliper in place wasnt springy. i had to beat the caliper on after replacing the pads. the outside pad always makes contact with the rotor and was riding it pretty hard. will i get away with this?
Old Feb 28, 2011 | 06:52 PM
hiwords's Avatar
what spring bolt? the caliper is held on by caliper pins. these are floating calipers. did you set up the caliper properly when you replaced the pads? i don't understand why it needed to be beat back on, there's plenty of room when the piston is all the way in the caliper
Old Feb 28, 2011 | 07:14 PM
its the stock caliper. when you take out the two bolts that hold it on, the nuts have spring action to them. the bottom one didnt spring back in, so the caliper had to be squeezed over the outermost pad and the part that the bolt threads into.
Mossyoakglock
Jun 19, 2013 10:31 AM
Mossyoakglock
Jun 18, 2013 11:32 PM
markbad311
Feb 1, 2013 07:57 AM
supermantfl
Jul 5, 2009 11:29 AM
