brakes
Old Sep 6, 2004 | 12:11 AM
KloepferN's Avatar
Default brakes
i need help changing my brake pads. is there a certain way that the c-clamp has to be on the caliper to push it back in so i can put the new pads on????? i know its a stupid question
Old Sep 6, 2004 | 12:13 AM
Jestnomen's Avatar
6th Gear
Default RE: brakes
Depends, front or back? If it is the front, there is no special way. Just stick the clamp on and push the piston back in. Make sure you keep your brake fluid resevour cap open. If you are trying to push the rear piston back in, you have to get a special cube tool, sold at autozone/advanceauto.
Old Sep 6, 2004 | 12:18 AM
KloepferN's Avatar
Default RE: brakes
what does it look like or should they know??
Old Sep 6, 2004 | 12:21 AM
Jestnomen's Avatar
6th Gear
Default RE: brakes
What does what look like?? The special tool?
Old Sep 6, 2004 | 12:25 AM
KloepferN's Avatar
Default RE: brakes
never mind i found it on the web site... found out its a loaner u cant buy it
Old Sep 6, 2004 | 12:26 AM
Jestnomen's Avatar
6th Gear
Default RE: brakes
gggrrrreeeeeeaaatttt
Old Sep 6, 2004 | 12:31 AM
ChrisB's Avatar
Default RE: brakes
original quote from tbrumley from: https://www.audiforums.com/m_10990/m...//tm.htm#12662
"The rear piston needs to be turned to go in, while the front can be pushed in with brute force. The NAPA part mentioned below, I also purchased fro around $10.00. It is the GM-Ford Disc Brake Piston Tool, part number 3355. You can use your rachet to attach to this part, it will help give you more torque. Hope this helps.. "
Old Sep 6, 2004 | 02:50 AM
SlimChriz's Avatar
Default RE: brakes
I know from experience that if get a loaner tool from autozone you have to put down a deposite but if you want to keep it just keep it they will just keep the deposit and buy a new one
Old Sep 6, 2004 | 04:23 PM
KloepferN's Avatar
Default RE: brakes
its only 35 dollars at autozone for the loaner. i might just keep it
Old Sep 7, 2004 | 12:28 AM
SlimChriz's Avatar
Default RE: brakes
Lol [sm=guilty.gif]
feels evil even though you actualy pay for it
