brakes
Depends, front or back? If it is the front, there is no special way. Just stick the clamp on and push the piston back in. Make sure you keep your brake fluid resevour cap open. If you are trying to push the rear piston back in, you have to get a special cube tool, sold at autozone/advanceauto.
original quote from tbrumley from: https://www.audiforums.com/m_10990/m...//tm.htm#12662
"The rear piston needs to be turned to go in, while the front can be pushed in with brute force. The NAPA part mentioned below, I also purchased fro around $10.00. It is the GM-Ford Disc Brake Piston Tool, part number 3355. You can use your rachet to attach to this part, it will help give you more torque. Hope this helps.. "
