brakes
Old Dec 11, 2007 | 02:26 PM
darkstaraudi's Avatar
Default brakes
i have a 2000 a4 quattro and am changing front brakes and cant get the calipper back between the brakes any one know whats up
Old Dec 11, 2007 | 03:06 PM
CRAZYHAWK's Avatar
Default RE: brakes
Do you mean, you can't push the piston into the caliper?
Old Dec 11, 2007 | 03:42 PM
Darknight101's Avatar
Default RE: brakes
You might what to get some C clamps. You can squeeze the pistons back into the calipers which will allow you to get the caliper back on. You can also do it if you have killer grip thats how I do it takes longer but a little safer.
Old Dec 11, 2007 | 03:46 PM
bob12312357's Avatar
Default RE: brakes
Try opening the master cylinder and using a C-clamp. If one sides brake pad is more worn then the other and you already got 1 side in already u may have a seized caliper and might have 2 shoot the piston out. We need a more detailed explanation of the problem and what you have done so far to solve it.
Old Dec 11, 2007 | 05:20 PM
Papachristou's Avatar
Default RE: brakes
like others said, c clamp or large pliars with the old pads can work too, on b6 rear calipers, you must rotate them while pushing them in... be sure to open the brake fluid container before doing it though and keep an eye on it to make sure it doesnt overflow!
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
