Brakes b6
Old Apr 23, 2007 | 04:28 AM
audiprotein's Avatar
Default Brakes b6
Ok, i have 2003 a4 1.8t. My rotors has to be changed soon. So i'm thinking about an upgrade. I've read that stock calipers from 3.0 would make 1.8t brakes better. So what i want is: new rotors (front) and maybe (rear) drilled ones, new calipers with good pads. Any suggestions, what should i go with?
Old Apr 23, 2007 | 06:38 AM
PandaXpress's Avatar
Default RE: Brakes b6
stock calipers are the same for the 3.0 and 1.8t
its just the rotorsand carriersare larger
if u want to upgrade the brakes and low on funds go wit S4 brakes
the stock B6/B7 calipers and carriers are a direct fit
if u wanna go cheaper u can get the b5 S4 the calipers and carriers are a direct bolt on also
Old Apr 23, 2007 | 10:43 AM
Amze's Avatar
Hmm, never knew that. Thanks for the heads up panda. Is the braking difference worth the extra $$?
Old Apr 23, 2007 | 12:26 PM
PandaXpress, is that b5 or b6 s4 u are talking about? What kind of rotors should i go with?
Old Apr 23, 2007 | 04:51 PM
ORIGINAL: audiprotein
read carefully, i said both the b5 and b6 can fit on our cars
the b6/b7s are more expenisive then the b5 s4s
the funny thing is b5 S4s brakes cant fit on B5 a4 brakes
Old Apr 23, 2007 | 10:56 PM
04a4's Avatar
i just got porsche brakes, from the 993 porsche.... Ceramic brake pads w/ cross and slotted rotors... they are awsome and definatly worth the buy...the car drives soooooooooooo much better now that they are installed and responds soo much better when you are entering and exiting the turns. Ohh the late braking and wow do they stop good
Old Apr 24, 2007 | 04:19 AM
PandaXpresssorry, was in a hurry.. thanks for a quick answer!!! By the way, you havent replied to me yet, what happened to your Votex kit?
Old Apr 24, 2007 | 04:21 AM
04a4how much did you spend on it (without a labor)???
Old Apr 24, 2007 | 04:30 AM
and 04a4 did u get special carriers or are u using stock carriers for those porsche capliers
mharris23
Jun 19, 2009 08:59 AM
DomsA4
Apr 24, 2008 06:53 PM
milla290
Jul 19, 2007 01:31 AM
dtownhotcorner
Sep 22, 2006 11:49 PM
dscott
Jul 4, 2006 06:14 AM
