brakes Rotors
Old May 15, 2006 | 03:12 AM
My A4's Avatar
Default brakes Rotors
i just got my brakes and rotors replaced all OE parts fit perfectly no problem no warning lights, but when taken for a test drive found when u brake at say traveling about 50 km or higher harder on the brake pedal right side front makes a large thumping noise like thump thump till complete stop only one side ( right ) but if braking slowly at the same speed or higer on the pedal no thumping noise from any where of the car till complete stop .. any one occur that in past or any idea or suggestion i want to void Dealer ship as much as possible,
wild guess i am taking is the right rotor may be defective or bumpy
thanks
Malik
Old May 15, 2006 | 03:32 AM
onepoint8tee's Avatar
Default RE: brakes Rotors
Your pad(s) may not be seated in the carrier/caliper the right way.
Old May 15, 2006 | 11:20 AM
Jestnomen's Avatar
6th Gear
Possibly a warped rotor?
Old May 15, 2006 | 12:48 PM
My A4's Avatar
thats what i was thinking too thanks jestnormen and onepoint8tee i thought about that too so right away to took the pads of the carrier/caliper and reseated them again and still so no change so i am thinking rotor or could the i guess its called the carrier/caliper spring that sits in the front long one .. because the left side the spring was good and the right side was loose.. ...
thanks
malik
boomshine
Jan 21, 2010 07:43 PM
Jessecoy
Jul 10, 2009 10:22 AM
wammy18
Aug 10, 2008 11:48 AM
klum00
Aug 29, 2006 01:13 AM
damir21
Jul 18, 2006 11:10 AM
