break (ABS?) and clutch (?) problems
Old Apr 24, 2006 | 12:06 PM
wolf's Avatar
Default break (ABS?) and clutch (?) problems
Hi,
My 5 year-old, so far very trustful A4 Quattro started giving me trouble:
1. When I break, and I am almost stopped (10-15 km.h) the break pedal suddenly starts pumping as the wheels would be slipping and the car stops promptly (like breaks would jam). When I release teh break pedal I can hear a 1-2 second buzzing noise.
2. After driving wiht high speed, or uphill on a hot day I hear a scary noise from the power-train, like fanblades hitting an obstacle in their way.
Could anyone, please, give me some hint?
Old Apr 24, 2006 | 01:01 PM
techbod's Avatar
Default RE: break (ABS?) and clutch (?) problems
sounds like you need to have a look at the condition of the pads/rotors, the peddle does pulse on breaking with ABS that's normal
Old May 2, 2006 | 08:52 AM
wolf's Avatar
Hi Dave,
Thank you for the reply. The discs and the pads were changed a year ago (approx. 20000km ago).
I should have mentioned that I can hear the ABS working (buzzing) below 6km/h, when it should actually turn off itself. This is when the sudden decelaration happens, as well. Where could I find a description of the Audi ABS system from other source than the Service Manual? Similarly where could I find a description of the Audi clutch or the entire transmission chain (for quattro)?
Best regards,
Emil.
Old May 2, 2006 | 07:29 PM
AteUrV8's Avatar
any dummy lights on??
Old May 3, 2006 | 05:50 AM
wolf's Avatar
Thanks. No lights on. I took it to the autoclub and they did not get any fault from the OBD. The breaks are all good - pads and discs. The problem is that the break james when I decelerate to below 5-6km/h. I think this is when the ABS suppose to deactivate itself.
Ist there any electronics control box for the ABS?
How could I re-initialize this?
How could I clean the ABS sensors?
Old May 3, 2006 | 05:53 AM
AteUrV8's Avatar
ORIGINAL: wolf
its definatelty one of your ABS sensors...same thing happened to my car and its just weird. I got a new sensor put in and everything went back to normal, the only thing that im questioning is my ABS and BRAKE dummy lights came on.
Old May 3, 2006 | 06:22 AM
wolf's Avatar
Thanks a lot. This is a much better use than having to change the pump. How did you find out which sensor is deffective? Was it a great deal for yourself to change the sensor? Does it require any "synchronization" afterwards or any other magic?
HulkB5
Jan 7, 2012 02:01 PM
loves4
Mar 4, 2008 12:41 PM
Paulyworld
Nov 27, 2007 02:31 PM
S4evr
Apr 12, 2007 04:50 AM
Bryceaudi
Sep 28, 2005 12:43 AM
