Break pads light on
my light is on as well. It comes on and goes off. yesterday, it was on all day. I have a good feeling its simply because of the cold at this point, messing with the sensor. Ill check the fluid just to make sure.
If your brake pads are low the brake fluid is gonna read as low becasue your calipers are pushed out a lot. when you get new brakes the calipers are pushed back in and your brake fluid level will go back up. Get new pads before adding fluid otherwise when you get new pads your just gonna take fluid out.
The dealer gave me new pads front and rear at 50K mi.
At 119K mi. my rear pads needed to be realaced. As
philmeister said the rears go first with no warning. At 120K mi.
the (O) lit up, and I replaced the front pads. There was plenty of
material left on the front pads when the electrical loop was
broken.
broken.
