Break pads light on
Old Jan 16, 2007 | 02:35 AM
robfresh's Avatar
Default RE: Break pads light on
When you do a brake check you can see for youself which pads need to be changed. I usually check them out once a month or every 2500 miles.
Old Feb 14, 2007 | 02:14 AM
nikotoma23's Avatar
Do the new pads come with the sensor or is that a dealewr item only?
Old Feb 14, 2007 | 02:43 AM
A4nicator's Avatar
my light is on as well. It comes on and goes off. yesterday, it was on all day. I have a good feeling its simply because of the cold at this point, messing with the sensor. Ill check the fluid just to make sure.
Old Feb 14, 2007 | 01:24 PM
CRAZYHAWK's Avatar
This indicator is for front pads or brake fluid:
(O)
Old Feb 14, 2007 | 01:40 PM
NuYorka103185's Avatar
If your brake pads are low the brake fluid is gonna read as low becasue your calipers are pushed out a lot. when you get new brakes the calipers are pushed back in and your brake fluid level will go back up. Get new pads before adding fluid otherwise when you get new pads your just gonna take fluid out.
Old Feb 14, 2007 | 03:17 PM
CRAZYHAWK's Avatar
This indicator will come on many times for brake fluid. It might
come on every 15K mi. needing brake fluid. Front brakes
should last 50K to 70K mi.
Old Feb 23, 2007 | 11:50 AM
CRAZYHAWK's Avatar
The dealer gave me new pads front and rear at 50K mi.
At 119K mi. my rear pads needed to be realaced. As
philmeister said the rears go first with no warning. At 120K mi.
the (O) lit up, and I replaced the front pads. There was plenty of
material left on the front pads when the electrical loop was
broken.
PaulMichael
Jul 29, 2013 03:50 PM
cnapmak
May 24, 2009 11:34 AM
EuroS4
Jul 26, 2007 02:49 AM
Black_97 A4
Jul 2, 2007 06:22 PM
aRIf
Jan 27, 2006 12:16 AM
