Building a 2.8 engine
Old May 6, 2006 | 02:33 AM
Sunaj's Avatar
Default Building a 2.8 engine
I have a 1999 a4 2.8 30v 5sp that I am trying to build the engine on. I am having difficulties finding performance components for it, any help would be much appreciated. Thank you!
Old May 6, 2006 | 02:34 AM
Jeff's Avatar
Zombie Defense Force
Default RE: Building a 2.8 engine
there arent any, just a super charger
Old May 6, 2006 | 02:38 AM
tip5's Avatar
theres equal lenght headers ive seen they were badass but empty your wallet to pick them up
Old May 6, 2006 | 03:03 AM
Sunaj's Avatar
You don't by chance remember the brand name do you?
Old May 6, 2006 | 07:13 AM
BadLuckAudi's Avatar
check the sticky links or the 2.8 page they can send you in the right direction but im with jeff just supercharge it
Old May 6, 2006 | 09:09 AM
sandman's Avatar
yes, when it comes to big gains all you have to choose from is a PES supercharger, again check those 30v links on the top.
Old May 7, 2006 | 01:14 AM
Sunaj's Avatar
Cool, yeah I'm basically trying to build this to take on stockish STIs hopefully I can do it under $10k... Might go a little higher if I need to, all depends on how much cash I'll have floating around...
Old May 7, 2006 | 02:03 AM
Sunaj's Avatar
OK, need help again... [&:] I am having finding a 2.8 30v for $2kish with decent miles (hopefully under 70k), any ideas? And ebaymotors is not helping...
Old May 7, 2006 | 01:47 PM
Slowb5's Avatar
uhh....you might have some troubles there chief. finding a audi for 2k....
and as far as a 2.8 goes....supercharger..$5000...cams, idk. exhaust, intake, port polish intake mani....chip...clutch...
might as well go for a 1.8 and get a bt deal...for under $5000...and be faster than that 2.8. just my $.o2
Old May 7, 2006 | 04:16 PM
Grouse's Avatar
Supresprint makes the headers, 1400 usd, they require you to remove the engine to install them. so figure a 500-700 for install They are designed to work with the pes supercharger. Putting them on your NA un s/c will cause you to loose your low end. when pes tested them they showed a nominal improvement of 5-8 hp accross multiple runs. I was told that was to close to error diviation on the dyno.
NOS is hit and mis from what i under stand the 2.8 ecu has issues with programming.
There is a co. that makes pistons, and junk for the 2.8 your best bet is to call Matrix intergrated and ask about that. Jermy has some knowledge of the 2.8 engine. In my conversations he said it was a bit unrealistic to do most of that work, but it could be done.
As a note PES has stated that over 10psi the engine can have issues. In my faq at the top of the page you'll find dyno's and other info about the 2.8/3.0 engines. Most of the parts links will get you in the right direction, you'll have to select your car and engine to get the right part.
