burning smell?
Old Jan 5, 2007 | 12:27 AM
4ringstuned's Avatar
Default burning smell?
Over the past few months, when I turn the car on and drive for the first 5 or 10 minutes, I smell a faint burning smell inside the car. I went to the front of the car and put my nose by the grill, and smelled a strong burning smell. any ideas?
Old Jan 5, 2007 | 12:47 AM
onepoint8tee's Avatar
Default RE: burning smell?
check your valve cover gasket. if it goes bad youll leak some oil onto the hot engine block and manifold which will smell.
Also, if you have manual tranny aworn out or slipping clutch will stink like ***.
Old Jan 5, 2007 | 12:51 AM
thanks onepoint8ee. It's auto, but I'll def check the valve cover gasket. thanks a lot for your help.
Old Jan 5, 2007 | 01:58 AM
Amze's Avatar
Could be your clutch... Hopefully it's not. Has your car taken any noticable change in acceleration right off the gear change? Well first off is your car even manual?
Old Jan 5, 2007 | 02:25 AM
khj677turbo's Avatar
Or turbo, mine does that too even if i go into a little bit off boost when i start or stop, i could give a ****, im getting rid of that ko3 monday
Old Jan 5, 2007 | 03:47 AM
Sp33d07's Avatar
ORIGINAL: 4ringstuned
ORIGINAL: Amze
read before you type
spikezone2004
May 5, 2012 12:01 PM
moeron7
Nov 8, 2010 01:32 AM
MarkR540
Aug 15, 2010 02:35 PM
PJK76
Sep 15, 2008 12:46 PM
