Buying an audi help
Old Jan 13, 2014 | 08:20 PM
Fleener's Avatar
Default Buying an audi help
I'm planning on buying my first Audi. Its an 05 A4 quatro with 153k miles is there anything i should check for when i test drive it or look for
Thanks
Old Jan 14, 2014 | 09:24 AM
rhodes991's Avatar
Read the stickies for lots of good information. You didn't say if it is a 2.0T, 3.0 (not sure if the 1.8T was offered in 2005). That will make a difference.
If it is a 2.0 check if the timing belt/water pump/cam follower have been replaced. If not they all need to be and that can run around $1k depending on where you have the work done.
Make sure the motor mounts look good (if you hearing a clunking noise while driving that could be an indication they are going bad). Don't recall the cost to replace those.
If it has been maintained these cars can go a long time (I have 130k on mine with a timing belt replacement as the only major repair).
Old Jan 21, 2014 | 11:40 AM
edubz's Avatar
is it true the time belt could be a nightmare? I heard if they break, because of the audi engine, it will break the whole engine, rendering the car useless..
I keep hearing about these timing belts and hear its a nightmare
Zeeborg
Apr 8, 2011 11:06 PM
Inspite
Aug 20, 2010 10:38 PM
deasonator
Jun 30, 2009 11:59 PM
BWillis
Dec 6, 2007 01:09 PM
BIG_head_2k6
Feb 13, 2006 02:32 AM
