A/C
Old Jun 3, 2005 | 02:56 AM
KloepferN's Avatar
Default A/C
to charge your a/c does anyone know what to charge it with???
Old Jun 3, 2005 | 09:37 AM
david9999's Avatar
Default RE: A/C
I know what to charge my car with, but I don't know your car, year or model. You might want to check under your hood and check the sticker which should tell you
Most likely it is 134a, but some info on your car would help.
Old Jun 3, 2005 | 12:20 PM
CRAZYHAWK's Avatar
Default RE: A/C
On a 2000 1.8T remove the plastic around the battery. The low pressure side has the larger diameter pipe, and will be colder when the compresssor is running. Interdynamics makes a 19oz can that contains R134A , lubricant , stop leak and a gauge for $25. With the compressor on , add to the low pressure side.
Old Jun 3, 2005 | 02:30 PM
KloepferN's Avatar
Default RE: A/C
my car is a 2000 A4 1.8T Q
Old Jun 3, 2005 | 08:28 PM
CRAZYHAWK's Avatar
Default RE: A/C
I knew that.
Old Jun 4, 2005 | 12:08 AM
Shaunp05's Avatar
Default RE: A/C
Why you want to charge it ?
Is your system running low if so
get it checked out, maybe you have a leak
and its good to get it recoverd and vacum checked
you remove the moister in the system
and your parts loast longer
Evap etc...
Old Jun 4, 2005 | 12:28 AM
BFlan2001's Avatar
Default RE: A/C
so when did those a-holes decide to be decent human beings by adding a low pressure port to the a/c system?? is it just us poor 12Vers without that luxury?
Old Jun 4, 2005 | 12:44 PM
CRAZYHAWK's Avatar
Default RE: A/C
There should be a low pressure valve in your car. It should be next to the high pressure one, have a larger diameter pipe and run colder.
