Calling the masters..I am stumped on this problem??
Old Jan 24, 2007 | 04:15 PM
Pson's Avatar
Default RE: Calling the masters..I am stumped on this problem??
ORIGINAL: acetrebo
Are the coilpacks hard to get to on the v6? Mines a 4-banger.
I mean, you had to remove the coilpacks when you changed the spark plugs, was it difficult to get to them?
No but there is only one coilpack (front of the V6)and the wires go into the block. so I would have to pull one wire off the plug to do the test
Old Jan 24, 2007 | 04:18 PM
Pson's Avatar
ORIGINAL: acetrebo
Pulling the neg battery cable is an easier way to reset the ecu without having to remove it.
Cool I will try this...I also got this answer from another forum too (you where first) and he stated if the idle spiked at the light then that is most likly the iusse that the TB needs to be setup or a coolant sensor (but my temp level is fine and stays put on the middle line)
Old Jan 24, 2007 | 04:35 PM
acetrebo's Avatar
ORIGINAL: Pson
That will have the same effect. You are just trying to find which cylinder is missfiring. I did not realize the v6 does not have a coil-over-plug setup.
How do the plug wires look? are you sure all of them are tightlyover the spark plug? Maybe one has a bad connection, or a short in it.
I would still think you would get a code, but its worth a shot trying to diagnose it if the ecu reset and TBA dont work.
It could also be a dirty injector, you may want to try some injector cleaner and see if that helps.
Old Jan 24, 2007 | 04:52 PM
techbod's Avatar
check the RPM sensor
edit: forgot pictures cough
Old Jan 24, 2007 | 04:56 PM
Pson's Avatar
ORIGINAL: acetrebo
ORIGINAL: Pson
Ok now I have run seafoam in both the gas tank and the combustion camber too and it happened for a few mins then right back to where it was. I am going to try the TBA tonight as well...but for the inj do they really ever go bad?? Or just replace the gaskets will maybe help??
techbod's Avatar
[IMG]local://upfiles/12092/6D6B3028382B48A8B5E486290A61F344.jpg[/IMG]
Old Jan 24, 2007 | 04:57 PM
Pson's Avatar
ORIGINAL: avant80@2.6
I have never read on even seen that we have this....I see the pic below where is this thing at ??
Also thank you guys for really taking the time to help me out on this one too
Old Jan 24, 2007 | 05:05 PM
  #18
acetrebo's Avatar
ORIGINAL: Pson
Injectors can go bad, but more often they get dirty/clogged. Try the other things first before you start messing with injectors. IE, test rpm sensor, find out where the misfire is exactly. Then, go from there.
Old Jan 24, 2007 | 05:08 PM
  #19
techbod's Avatar
[IMG]local://upfiles/12092/69A65213C9DA4C899A9B70A050B6E941.jpg[/IMG]
Old Jan 24, 2007 | 05:13 PM
  #20
Pson's Avatar
ORIGINAL: acetrebo
ORIGINAL: Pson
Hmmm...ok How do I test the rpm sensor? or do I need the Vag for that one? Also I saw the pick thank you for it its seems to be right on the drivers side fuel rail too. I will take a look tonight and clean off the sensor with cleaner and do a TBA as well. I looked for a few mins on the EKTA part list and couldn't find anything with that rpm sensor so again thank you for pointing me in the right way.
