CAM CHAIN TENSIONER
Old Apr 28, 2007 | 10:23 PM
  #21
auditech79's Avatar
Default RE: CAM CHAIN TENSIONER
Yeah, but im not sure you can purchase the tool seperately. All the techs get theirs when they install a new chain tensioner which comes with the tool. Its not very expensive, i have 3 maybe you wanna buy it?
Old Apr 28, 2007 | 10:32 PM
  #22
onepoint8tee's Avatar
I see one on ebay. I dont need it, at least now. Ill let you know if i ever do though. Is the cam chain tensioner on a 2.8 similar to the one in a 1.8t i take it? I found this: http://www.robsaudiworld.com/2.8camseal.htm But it doesnt explain how to remove the tensioner. Im guessing you have to remove it all together, both cams/sprokets/chain and tensioner still all in once piece (basically)?? How do you get the cams/sprokets and everything to line up correctly when you put it back together??
Old Apr 28, 2007 | 10:40 PM
  #23
auditech79's Avatar
1.8 cyliner heads are identical to 2.8 heads just has one less cylinder. If your going to do the tensioner and not the seal you un-bolt both the cam shafts and the tensioner (zip tie the timing belt onto the cam sprocket so it won't lose its timing) then lift the cam shafts and the tensioner from the rear off the head and roll out the tensioner from the chain and ta da. Like it said in the instructions make sure you have exactly 16 links in the chain when re-installing it so it won't throw a cam allocation fault. (Thats the hardest part it can be a bitch to get exactly 16 chain links, it takes practice)
Old Apr 28, 2007 | 10:43 PM
  #24
Thanks for the info. Where do you live incase I ever need someone with practice to help me do this? I like to be prepared for these kinds of things.
NM, i see your profile. We are on oposite sides of the country.
Old Apr 28, 2007 | 10:48 PM
  #25
auditech79's Avatar
In sacramento, but i'll be happy to show you how to for free if ya wanna learn, i just left audi and the mechanic world two weeks ago so i have about 60k worth of snap on and mac tools in my garage.
Any by the way if anyone wants to buy some tools from me in sacramento i have too many of the damn things.
Old Apr 28, 2007 | 11:06 PM
  #26
cincyTT's Avatar
I'm make believe
You come to dayton and ill give you a hand if need be. I also have the tool.
Old Apr 29, 2007 | 12:25 AM
  #27
Thanks for the heads up
Old Apr 29, 2007 | 12:40 AM
  #28
Cruz734's Avatar
Any suggestions on where I should go from here. The noise is pinpointed its coming from the top-middle-rear(firewall side) of the engine compartment.
Where can I find info on the cam Chain tensioner? I've takenthis to3 mechanics and I have no idea what to do next.
Old Apr 29, 2007 | 02:59 AM
  #29
auditech79's Avatar
Sorry Cruz, there is two possible reasons the cam adjuster is making a noise, kinda sounds like a diesel engine when you start it right? The most probable reason is the engine is sludged (common) and isn't getting enough oil to the adjuster, have a mechanic check the oil pressure. If its ok change the cam adjuster.
Old Apr 29, 2007 | 05:31 PM
  #30
Cruz734's Avatar
Any tips for checking the oil pressure? My dad says he can do it he needs a place to plug into.
