camber cars
NEO gens are for camber cars, which is if your car is lowered of some sort. When you lower our cars the wheels will angle in "negative camber", to a certain degree depending on how low you go. Camber is kinda like this, the middle mark being 0 degrees "/ l \"
You shouldn't need neo gens if your car isn't lowered, other wise go with the nt-555s.
Good explanation. Bottom out more is negative camber, top out more (which is extremely bad) is positive camber.
And if your car is lowered, it's hard to adjust the camber with the stock components. So yeah, the "Negative camber is not so negative anymore" tires should be good for you.
And you do not say "camber cars." That doesn't even make sense. You say "your suspension has a lot of negative camber", or "that negative camber will ruin your treadlife," not "I have a camber car."
Sicknasty
Mar 12, 2008 11:20 PM
