camber cars
Old Sep 29, 2005 | 02:54 AM
juice88's Avatar
Default camber cars
what are camber cars and is the nitto neo gen for camber cars only, and what do yall think of the Nitto NT-555?
Thanks.
Old Sep 29, 2005 | 03:10 AM
trailboss's Avatar
Default RE: camber cars
NEO gens are for camber cars, which is if your car is lowered of some sort. When you lower our cars the wheels will angle in "negative camber", to a certain degree depending on how low you go. Camber is kinda like this, the middle mark being 0 degrees "/ l \"
You shouldn't need neo gens if your car isn't lowered, other wise go with the nt-555s.
Old Sep 29, 2005 | 02:55 PM
Yuikio's Avatar
Good explanation. Bottom out more is negative camber, top out more (which is extremely bad) is positive camber.
And if your car is lowered, it's hard to adjust the camber with the stock components. So yeah, the "Negative camber is not so negative anymore" tires should be good for you.
And you do not say "camber cars." That doesn't even make sense. You say "your suspension has a lot of negative camber", or "that negative camber will ruin your treadlife," not "I have a camber car."
DEjunkie
Jun 8, 2008 10:06 AM
Sicknasty
Mar 12, 2008 11:20 PM
LowClassA4
Feb 6, 2008 09:38 AM
VB05
Feb 1, 2007 06:58 PM
mypreludeisred
Jun 24, 2006 05:04 AM
