camber kits ?
Old Mar 22, 2005 | 07:43 PM
turbo's Avatar
Default camber kits ?
I want to do front and rear camber kits on my 02 A4 b6 and just want to know if it is a pain in the *** to put in.
Just so I know what I am in for ,and if there will be down time for the car to do this.
Thanks
Old Mar 22, 2005 | 07:45 PM
Jestnomen's Avatar
6th Gear
Default RE: camber kits ?
Why how much of a drop do you have?
Old Mar 22, 2005 | 07:58 PM
turbo's Avatar
well I have coil overs and its about 2 to 2 1/4 with stock wheels.
I have 19" s and I will put them on in a week or two depending on weather so I may have to rase it up so I dont rubb
Old Mar 22, 2005 | 09:47 PM
Shaunp05's Avatar
its not that bad to do, its mainly both upper control arms that are adjustable
therr pretty sweet you can do Caster/ Camber on each wheel up to 3.5 Degrees
on camber So its realy worth it in the long run if you changed your ride height
What kit you going with ?
Old Mar 22, 2005 | 10:57 PM
turbo's Avatar
well all I have seen is the Eibach kit. Is there outher kits that are beter.
The eibach kit is $140 for front and $140 for rear
Old Mar 22, 2005 | 11:03 PM
Shaunp05's Avatar
http://www.kompressorkanada.ca/pages...pcrtl-audi.htm
this guys have a kit and it does both side ..
the Eibach kit does it do both sides or one side ?
Newaudiguy99.5
Aug 25, 2011 11:23 AM
Newaudiguy99.5
Aug 19, 2011 12:37 PM
Newaudiguy99.5
Aug 17, 2011 02:32 PM
cmacelo121
Feb 24, 2010 10:41 AM
cstarky15
Jan 26, 2007 04:46 PM
