can it be the control arms?
OK when im driving real slow, and i hit a minor bump, i hear a squeaky sound from the front area. can it be my upper arms? Also does have bad upper control arms mess up your alignment?
your alignment will be fine. It does sound like your control arms.
check here
check here
would you kno whether it bushing or ball joint on my 99.5? after noticing my tierods were bad from wigglin the tire left to right i changed them. now the left is good, but right still has a bit of movement. therefor it seem the movin point o found was the linkage to the upper arm. but im not sure if its bushing or ball joint
Hey guys..long time
anyway I started having the same problem in my drivers side front...its the "clunk sound" or ball joint that brrman was talking about...
my question is do I replace all my controll arms ?? what is the fix??
I thought I needed new shocks..but I only have 68000 and its a 2000..
please let me know
thanks
T
please let me know
thanks
T
jdahlen24
Aug 25, 2011 09:50 PM
jdahlen24
Aug 25, 2011 03:05 PM
