Can I use ABS Module from other car (parted out) to replace mine?
Old Jul 6, 2007 | 06:20 PM
Donz0r's Avatar
Default Can I use ABS Module from other car (parted out) to replace mine?
I have the ABS light on steady and the Brake light flashing on my car constantly.
I understand that the ABS module is bad from searching.
Can I get an ABS module from a different a4 (perhaps one being parted out) and put it on my car? Or is it somehow
car specific in some way?
Thanks,
Don
Old Jul 6, 2007 | 08:54 PM
onepoint8tee's Avatar
Default RE: Can I use ABS Module from other car (parted out) to replace mine?
Sure. You can also get one from an A6, A8, or S4 as long as its from the same chasis (B5/B6)
Old Jul 6, 2007 | 09:11 PM
Trey25's Avatar
Definitely, just make sure the letter at the end of the part number is the same.
The OEM part numbers and ending letter designation effected are: 8E0614111-P, Q, R, S, C, G, M, H, A, N, E, , B, F, AH, AJ, D,& 3B0614111. This number & letter code can be found on the Pump Assembly housing between the brake lines.
HKS
Jun 9, 2015 02:05 AM
mrjagdad
Apr 7, 2014 05:21 PM
mxw
Jun 6, 2011 08:19 AM
pongpeera
Apr 17, 2010 10:40 PM
AudiGary
Aug 27, 2008 04:01 PM
